Arcade Script to pull a intersect value from overlapping polygon layers based on a inputted value.
1432
06-20-2024 09:11 AM
jmcdonald_sdi
Hey AGOL Blog,
I have 5 overlapping/stacked floor layers that each have a room_id attribute. I'm trying to run a script that checks a floor value inputted by the user in a separate field and returns the room_id value for that specific floor.
// Check the value of the room level field: values are "base" "lowr" "uppr" "pent" "mezz"
var roomlevel = $feature.Room_Level
// Create a feature set using the 'Basement' layer in the map
var based = FeatureSetByName($map, "BORG_Basement_Level")
// Intersect the current location with the the level and
// get the first intersecting room
var base1 = First(Intersects($feature, based))
// Create a feature set using the 'Lower' layer in the map
var lowerd = FeatureSetByName($map, "BORG_LowerLevel")
var lower1 = First(Intersects($feature, lowerd))
// Create a feature set using the 'Upper' layer in the map
var upperd = FeatureSetByName($map, "BORG_UpperLevel")
var upper1 = First(Intersects($feature, upperd))
// Create a feature set using the 'Penthouse' layer in the map
var pentd = FeatureSetByName($map, "BORG_Penthouse")
var pent1 = First(Intersects($feature, pentd))
// Create a feature set using the 'Mezzanine' layer in the map
var mezzd = FeatureSetByName($map, "BORG_Mezzanine")
var mezz1 = First(Intersects($feature, mezzd))
// If the current location does intersect a feature,
// return the name of the region. Otherwise, return null
return When(
  roomlevel == "base", base1['room_id'],
  roomlevel == "lowr", lower1['room_id'],
  roomlevel == "uppr", upper1['room_id'],
  roomlevel == "pent", pent1['room_id'],
  roomlevel == "mezz", mezz1['room_id']
The final part of the script is where I'm having the most trouble, I don't know how to format the script to output the desired value reliably. Right now can only make it return the basement value.
Thanks!
KenBuja
MVP Esteemed Contributor
Since you know which floor the feature is on, why run all the intersections? Just run it once according to the floor.
var floor = Decode(roomlevel,
  "base", "BORG_Basement_Level",
  "lowr", "BORG_LowerLevel",
  "uppr", "BORG_UpperLevel",
  "pent", "BORG_Penthouse",
  "mezz", "BORG_Mezzanine")
var fs = FeatureSetByName($map, floor)
var location = First(Intersects($feature, fs));
iif(IsEmpty(location), null, location['room_id'])
