Arcade Popups with multiple web links
2095
08-30-2022 10:35 AM
John_Shell
I need to be able to show data with a one to many relationship. I have the data coming out correctly but the links are merging together into one web link. I need the links to be individual links.
2 Solutions
JohannesLindner
This is the map we're talking about: Tacoma City Council Districts Web Map Update-Copy (arcgis.com)
The old and hard way:
  • figure out how many links you need at max
    • let's say the biggest district has 5 neighbothood counlics, then you need 5 links.
  • create the expressions:
    • for each council: 1 expression for the name, 1 for the url
  • create the popup
// Expression for the name
index = 0  // <- change this number in each name expression
var areas =FeatureSetByName($map,"Neighborhood Council Districts (Tacoma)");
var Onefifty = Buffer($Feature, -150, 'feet')
var countp = Intersects(areas,Onefifty);
var i = 0
for(var c in countp) {
    if(i == index) {
        return c.Neighborhood
    i++
return ''
// Expression for the url
var i = 0
    if(i == index) {
        return c.URL
    i++
return ''
Your popup would look like this:
The new and far better way: Just use an Arcade element! With this element, you can return HTML code which will be interpreted by the popup.
var result = "";
for (var item in countp){
    var name = item["Neighborhood"];
    var url = item["URL"]
    result += `<a href="${url}" target="_blank">${name}</a><br/>`
return {
	type : 'text',
	text : result
Have a great day!
Johannes
John_Shell
Hi Johannes,
Thank you so very much! I love seeing this work. I really want to dive deeper into Arcade and now I can learn more about Arcade elements. It all makes sense now because I had been seeing other examples of people using Html code in their Arcade code. Now I can finish up this little project and on to my next project. I hope you have a fantastic day. You have definitely made a new friend for life.
Thank you,
John
JohannesLindner
  • create the popup
var i = 0
    if(i == index) {
    i++
return ''
var i = 0
    if(i == index) {
        return c.URL
    i++
return ''
var result = "";
return {
	type : 'text',
	text : result
Have a great day!
Johannes
John_Shell
Hi Johannes,
Thank you,
John
DaveSivertsenz
Thanks for the helpful tips! The link to the map requires credentials, and is not accessible for most of the community.
PedroSoares1
Hi, sorry I could not be of much help, as I have been away. I am glad you have the problem solved.
cheers, good luck on your 'exploration'.
Pedro
