Arcade Pop-up: Better option than intersect to pull data from another layer
1113
10-10-2024 02:04 PM
Labels (2)
ChrisMcGovern
Hi All,
I'm using an arcade pop-up to pull existing and proposed zoning into a parcel layer. The zones are coming from a separate layer so i am using the "Intersects" arcade function to add this data into the parcels layer.
However I am returning multiple zone values for edge cases. Where a parcel is on the edge (similar to intersect in a select by location) I am getting a zones that do not reflect the correct zones. Any better way to use arcade ?
Arcade
ChristopherCounsell
MVP Frequent Contributor
Use Intersection then iterate through the featureset to return the largest value i.e. the greatest level of overlap.
Example here:
https://community.esri.com/t5/arcgis-online-questions/arcade-intersects-return-greatest-overlap-of/t...
jcarlson
MVP Alum
We do this, and have seen this problem as well. Possible solutions:
  1. Use Intersects(points, Centroid($feature)) to grab only the zone that falls under the center of the parcel. Works great unless the parcel has a wonky shape.
  2. Use Intersects(points, Buffer($feature, -5)) to back off from the parcel edge a little.
You could actually do both, too. You can check the truth of Intersects($feature, Centroid($feature)) to see if you have a wonky shape, then use the negative buffer, but default to the centroid method for "normal" parcel shapes.
- Josh Carlson
Kendall County GIS
