Arcade: How do I find the first empty field?
686
05-29-2022 06:15 AM
neomapper
How do I get the variable loopResults to find the first empty field and return it back to the stages variable for id:0, labeled Engineering? When I load the script, loopResults always returns project_designed if it's not empty
var Project_Design = Date($datapoint["Project_Designed"])
var PA_Sent = Date($datapoint["PA_Sent"])
var PA_Recvd = Date($datapoint["PA_Recvd"])
var loopResults = When(!IsEmpty(Project_Design), Project_Design,
					   !IsEmpty(PA_Sent), PA_Sent,
					   !IsEmpty(PA_Recvd), PA_Recvd,'')
var stages = [
        label: "Engineering",
        completionDate: loopResults,
        threshold: 60
        label: "CSR",
        completionDate: $datapoint["App_to_Processing"],
        threshold: 60
        label: "Operations",
        completionDate: $datapoint["To_Operations"],
        threshold: 5*60
        label: "Construction",
        completionDate: $datapoint["To_Construction"],
        threshold: 22*60
        label: "Done",
        completionDate: $datapoint["PA_Recvd"],
        threshold: null
JohannesLindner
You're currently looking for !IsEmpty(), so it returns the value of the first non-empty field. Remove the bangs:
var loopResults = When(IsEmpty(Project_Design), Project_Design,
Have a great day!
Johannes
