Arcade Filter/Relate not working in Popup
2827
10-21-2020 02:22 PM
ShawnLanning
Popup only shows the expression label and then no value even though the arcade expression works in the test expression window.  I followed the blog about using featuresets to create a relate and add it to a popup - https://community.esri.com/community/gis/web-gis/arcgisonline/blog/2020/06/09/show-related-data-or-t... - Gee Fernando's Blog
Here is my code:
// Write a script to return a value to show in the pop-up.
var portal = Portal("https://services.wygisc.org/portal")
var speciesRelate = FeatureSetByPortalItem(portal,
"6a0c8bcd1d164d99b76f162f140212f8", 0, ['Species', 'Taxa',
'Occurrence_Potential', 'BLM_Status',
'Texas_________________Status', 'Federal_Status', 'Habitat',
'Code'])
// Filter related features by using a common attribute
var HabCode = $feature.HabCode
var codeStatement = 'Code = @HabCode'
//Related features as a variable
var relateData = Filter(speciesRelate, codeStatement)
//build popupString by iterating through all related features
var popupString = ''
for (var f in relateData){
popupString += "Species: " + Text(f.Species) + TextFormatting.NewLine +
"Taxa: " + f.Taxa + TextFormatting.NewLine +
"Occurrence Potential: " + f.Occurrence_Potential + TextFormatting.NewLine +
Thoughts?
Shawn
XanderBakker
Esri Esteemed Contributor
Hi sgl55 ,
Not sure if you did not include the complete expression, but at the end you should return the "popupString". That is the main reason you are not getting any result.
var portal = Portal("https://services.wygisc.org/portal");
'Code']);
var HabCode = $feature.HabCode;
var codeStatement = 'Code = @HabCode';
var relateData = Filter(speciesRelate, codeStatement);
var popupString = '';
                   "Occurrence Potential: " + f["Occurrence_Potential"] +
                   TextFormatting.NewLine + TextFormatting.NewLine;
return popupString;
I would also recommend to access fields that contain an underscore using feature["Field_Name"] and nor as feature.Field_Name (see line 22).
Avoid on lines 4 to 6 to include fields that you are not using to increment performance.
KenBuja
MVP Esteemed Contributor
How are you linking the script to the popup? Do you have it checked in the Configure Attributes dialog?
ShawnLanning
Yes - I believe I have the pop-up configured correctly and even created a very simple arcade expression that does work, though I could be missing something?  See below:
XanderBakker
Hi sgl55 ,
'Code']);
return popupString;
