Arcade expression to grab layer setting description
795
11-01-2023 08:32 AM
cat206
Hi, does anyone know if you can write an Arcade expression to grap the description of the layer in the overview tab? It would be great to have this as a feature in the pop-up so we won't have to manually change layer names on what the data is representing in each map, instead we can change the description and it can be pulled through into the pop-up.
Example would be if we had accident data up to 2021 and then appending data for 2022, we could amend the description
