Hi all,
I am quite new to arcade so forgive me if the answer is way too obvious to everyone...
I'm trying to use arcade to change the symbology so it displays two different fields, each one with its own domain.
The fields are cleanseStatus and cycle. Both have a domain as well
I have used the expression:
($feature.cleanseStatus) + "," + ($feature.cycle)
But I only get the code for the cleanse status, and nothing for the cycle and also get the code for the different cleanseStatus and not the description.
Ideally I would like to see the cleanse status code description, then a coma, and then the cycle code description so I can adjust the symbology for each one independently.
Thanks a lot in advance.
Albert
