Arcade Expression - intersect FeatureSetbyID against secure ArcGIS server map service?
968
05-23-2022 01:23 PM
Labels (2)
LaraMulvaney
I'm new to Arcade.  Trying to set up Field Maps app for mobile workers.      Using intersect, I want to harvest an ID from a field in an existing secure map service to be used in an editable layer.    Use case example creation of Repair Operations Record point on an existing sewer gravity main.    I have seen example code for Intersect, and FeatureSetbyID, but wondering if this only works when map service is public.    Map Service not in Portal.
Can Arcade call a secure map service?  If so, how?   Thanks!
NickAddison
@LaraMulvaney Did you ever find a solution to this?
