Arcade error trapping - Test execution error: Unknown Error. Verify test data. query
2025
09-06-2023 05:00 PM
RyanBohan
I have an arcade statement, which was working fine.  However, the query function on the rest end points broke, which of course caused issues with my arcade statement.
I opened the arcade and was getting "Test execution error: Unknown Error. Verify test data." when I did a test run.
I attempted to catch the error with IsEmpty, that did not seem to work.  Trying to think of the best way to handle a broken rest service and return something to the user.  Which of course is hard to test, as I can't plan for when a rest endpoint might break.
Looking at the FEMA Rest Service
I know it would be best to fix the rest service, but it's not my organization.  So, I am looking for a way in arcade to catch any errors and display a default message "High demand on layer, results unavailable."
Tags (4)
ToddW_stl
I found your post and the idea below while researching something else.  Give it a kudo/vote if you think it may help!
https://community.esri.com/t5/arcgis-pro-ideas/add-error-handling-try-catch-to-arcade-language/idi-p...
