Arcade Error for Indicator Code
1621
02-06-2025 08:53 AM
JakeReichelt
I am trying to create an indicator that will display a number for both the number of critical infrastructures within an impacted area as well as the number of hospitals within an active evacuation zone. I am receiving an error message saying "Test execution error: Unknown Error. Verify test data." I am having a hard time deciphering what the issue with the code is.
Here is the code for reference:
//Layer source information
var p = portal('https://arcgis.com');
var crit_infra = FeatureSetByPortalItem(portal(p), 'fbb2f2bd73cb4ece92800d3527f9680d', 0, ['*']);
var impacted_area = FILTER(FeatureSetByPortalItem(portal(p), '996efbd08dc8478d9a9315a33ed50bda', 0, ['*']), "activeincid = 'Yes'");
var hcc_mem = FeatureSetByPortalItem(portal(p), '45e9dac6ea264c76818149c4b15717ea', 0, ['*']);
var evac_zone = FILTER(FeatureSetByPortalItem(portal(p), 'b84c5fc156f3420398e21b93c75c00b9', 0, ['*']), "activeincid = 'Yes'");
var final_count = 0;
//Get total count of critical infrastructure intersected by any active impacted areas
for(var i in impacted_area){
  var i_count = Count(Intersects(crit_infra, i))
  Console(i_count + ' critical infrastructure')
  final_count += i_count
  Console(final_count)
var hcc_count = 0;
//Get total count of hcc members intersected by any active evacuation zones
for (var j in evac_zone){
  var j_count = Count(Intersects(hcc_mem, j))
  Console(j_count + 'hcc members')
  hcc_count += j_count
  Console(hcc_count)
//Create data schema
var tabl = {
  'fields': [
    {'name': 'cntType',
    'type': 'esriFieldTypeString'},
    {'name': 'cntImpCI',
    'type': 'esriFieldTypeInteger'},
    {'name': 'cntTypes',
    {'name': 'cntHCC',
    'type': 'esriFieldTypeInteger'}],
  'geometryType': '',
  'features': [],
//add data to data schema
tabl.features[0] = {
  'attributes':{
    'cntType': 'Impacted Infrastructure',
    'cntImpCI': final_count,
    'cntTypes': 'HCC Members',
    'cntHCC': hcc_count,
//return the featureset
return FeatureSet(Text(tabl));
RhettZufelt
MVP Notable Contributor
Not able to test at the moment, but perhaps it is in the portal(p) in the FeatureSetByPortalItem.
Documentation shows:
var features = FeatureSetByPortalItem(Portal('https://www.arcgis.com'),'7b1fb95ab77f40bf8aa09c8b59045449',0,['Name', 'Count'],false);
and you have:
where you have already set the variable p = portal('https://arcgis.com') then in the FeatureSetByPortalItem it is basically calling portal(portal('https://arcgis.com')) (also, you might need the www in there as well p = portal('https://www.arcgis.com')
Perhaps something like this will work?
var p = Portal('https://www.arcgis.com');
var crit_infra = FeatureSetByPortalItem(p, 'fbb2f2bd73cb4ece92800d3527f9680d', 0, ['*']);
var impacted_area = FILTER(FeatureSetByPortalItem(p, '996efbd08dc8478d9a9315a33ed50bda', 0, ['*']), "activeincid = 'Yes'");
var hcc_mem = FeatureSetByPortalItem(p, '45e9dac6ea264c76818149c4b15717ea', 0, ['*']);
var evac_zone = FILTER(FeatureSetByPortalItem(p, 'b84c5fc156f3420398e21b93c75c00b9', 0, ['*']), "activeincid = 'Yes'");
R
EDIT:  just got a chance to test this with Indicator in a Dashboard and get the same error with your code, but not with my modifications, except, doesn't appear to need the www. in the portal URL.
RhettZufelt
and you have:
R
JakeReichelt
This seemed to work, thank you so much!
DavidSolari
MVP Regular Contributor
What Profile are you running this Arcade code in? If this was for a map popup, you'd be better off using FeatureSetByName with the $map global to reference the other layers.
For anything more complex, the Playground is the only way I know to test your expressions. Unfortunately the Playground can only access public data, so you'll either have to hunt down a set of public data that's close enough to your data, or create test data from scratch using the FeatureSet function. For what it's worth, I get the same "Verify test data" error in the playground so there might be a chance everything's working except accessing the data from AGOL, replacing that with test feature sets will help you isolate that issue.
JakeReichelt
This was for a dashboard indicator. Appreciate the response and I will look into this.
