Hi, I'm looking to append all the data held in a hosted table in ArcGIS Online to another table in a hosted feature layer (with an identical schema) using python.
I've attempted to use the API guidance, but every time I try I get an unknown error on the .append function
Exception: Unknown Error
(Error Code: 500)
Can anyone help with a code sample. All the examples in the guidance focus on CSVs rather than data already in AGOL
Hi @RichardHowe,
If you have an ArcGIS Pro license, use arcpy's Append within your code instead of the ArcGIS API. It will work with hosted feature services.
Hi @RichardHowe,
Thanks @JakeSkinner , that was very helpful. I don't know why that didn't occur to me!
Next question, while you're here. Is it possible to use toolbox validation with the AGOL GIS API. SO for example could I Update a script parameter to populate with every layer in a hosted feature layer for example?
@RichardHowe yes the validation will work with ArcGIS API. You just need to import the module.
