Anyone else having trouble accessing the ArcGIS Sign-in page? https://www.arcgis.com/home/signin.html
3508
14
08-01-2014 06:43 AM
KyleSpencer
The link doesn't load any browser I have. These are the errors I see when inspecting the element in using the chrome developer tools.
Tags (1)
KyleSpencer
Adrian,
I have tried accessing the site in Chrome, IE, and Firefox.
Stuart,
I tried adding the exception like this (screen grab) in chrome. But it still doesn't work.
V_StuartFoote
Guess could be a GPO policy setting if you are on a institutional system, what do your IT folks say?  You mention Symantec End-Point protection is involved--might ask them about configuration of that.
Otherwise, this link has the instructions for enabling JavaScript in common browsers.
http://www.enable-javascript.com/
Enabling globally may be too much, but you should be able to tailor things.  Also, should you have ScriptSafe or NoScript or similar installed, you may need to disable them to test.
Stuart
KyleSpencer
Yes, I have enabled all javascript.  IT folks have no clue, but I did just test it off our domain and it works fine.  So I will go pay our network security team another visit.
KyleSpencer
The problem seems to be with a secure link (https) to an IP address registered to cloudfront.com (amazon web services) when loading the sign-in page.  That IP address is categorized by Websense as “advertisements” which is blocked.  Our IT Security team re-categorized the IP address which is now allowing the sign-in page to load.  As long as they don't change the IP address it will continue to work.
V_StuartFoote
Good to know regards the Websense (or see its current Wikipedia article) blacklisting. Glad you got it sorted.
Stuart
