AGOL connecting OSM API in map view
2684
7
04-29-2024 07:44 PM
AndrewHankinson
I have tried to add an OSM API to a map view but when I try to add following the below
>Add layer from URL
>Paste in URL
>Select 'WMTS OGC'
I get an error - Service does not exist or is inaccessible.
When I add the same OSM API via the same method to map view classic it works fine.
What am I missing? Is this function just not available yet in the map view?
David_McRitchie
Hey Andrew,
Thanks for getting back and showing a screenshot. The key itself should go under Value and the word "key" should go under Parameter. Top of my head I cannot remember if it matters if this is capitalised so I would try this in upper and lower case.
Hopefully that fixes things. I would also suggest deleting that screenshot as the API key could be used by other users viewing the thread. With OpenStreetMap I don't think this could be done maliciously, but it could lead to rate limiting if someone spammed requests to the service.
Hope that helps!
David
Esri UK -Technical Support Analyst
govardh
For basic map loading, as OP is wanting, on native Android, it's free. Even for 500k+ requests. If they're using JavaScript embedded in a WebView, then that's a different story, but there's no need to use OSM for this unless you specifically do not want to use Google Maps.
David_McRitchie
Hey Andrew,
Is there a key with the API? If so then this will need to be added as a custom parameter when using Map Viewer, rather than being included in the WMTS URL.
Hope that helps!
David
AndrewHankinson
Hi @David_McRitchie ,
Thanks for getting back to me.
There is an Project API key and a Project API secret key.
I have tried to add the WMTS API Endpoint address and then entered in both of the above as a custom parameters (seperately) and I still get 'Service does not exist or is inaccessible'
I've added a screenshot for reference.
David_McRitchie
Hey Andrew,
Hope that helps!
David
AndrewHankinson
That's got it working, thank you.
Cheers,
Andy
KarenFergason1
I am having a similar issue - would it be possible to see the original screenshot with the API key lined out?
AndrewHankinson
Here you are @KarenFergason1
