AGO User Type confusion
2104
07-15-2019 03:42 PM
SteveCole
Honored Contributor
I want to look into the workflow of using Collector to collect field data. When I look at my AGO profile in my AGO organizational account, it lists that my role is "user" and my user type is "creator". I tried to follow along with this blog post about making a Collector map and the first step is to Create a Feature Layer. When I attempt this, Feature Layer and Tile Layer are not present as options under the Create Content button.
According to this blog post under the Capturing new crop data header, it states:
Creator – Supporting the work of the Agronomist, members with a minimum Creator user type can create new feature layers, maps, forms, and groups within the organization that can be shared with the Field Worker so that they can complete their field work.
So what's happening here? Can organizational admins override user type defaults?
Thanks-
Steve
Katie_Clark
MVP Regular Contributor
Hi Steve,
As a User role, you can create maps and edit features that are created by other users. However, to publish content to ArcGIS Online and create new hosted layers I believe you need the "Publisher" role. If you want to create a web map for use in Collector, you could try incorporating a feature layer that's already published by another user and has editing enabled. Or you could talk to your AGOL admin about getting a Publisher role.
For reference, here is more information about roles and user types: https://doc.arcgis.com/en/arcgis-online/reference/roles.htm
Hope that helps!
Best,
Katie
If this post helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
Katie_Clark
Hi Steve,
Hope that helps!
Best,
Katie
SteveCole
Honored Contributor
Thank you, Katherine. So, to be clear, the statement in the second blog post is incorrect?
Katie_Clark
I agree that it is a bit confusing....the way I understand it is that in that paragraph you reference, he is specifically talking about User Types. So in that case, yes, you do need a minimum of a creator User Type. However, that section doesn't talk about the Role necessary to complete those tasks in addition to having a Creator User Type.
Best,
Katie
