AGO embedded map problems with IE
5544
02-04-2015 12:20 PM
WaylonLang
I'm having trouble with an embedded map from ArcGIS Online showing up in Internet Explorer when the IE option for compatibility view is checked. It just comes in blank. Anyone else have the problem? Works fine in all other browsers. Also works when compatibility mode is unchecked. I'm using the AGO generated iframe code. Tested IE 10 and 11.
KellyHutchins
Esri Notable Contributor
I ran a quick test using an embed map and cannot reproduce the problem. Which settings have you enabled for the embed? Do you have a url to a page that shows the problem?
WaylonLang
https://www.dot.nd.gov/divisions/civilrights/dbeprogram.htm bottom of the page. Settings: zoom control, home button, w865 x h500.
KellyHutchins
Just ran a test using IE11 and can't reproduce. Works fine for me both with and without compatibility mode checked.
ChrisSergent
I tried it in IE11. It loads very slow. I didn't get the entire map until I pressed F5 two more times. Have you checked your browser to see if it is loading slow for you as well? The one error that I saw in Internet Explorer Developer Tools was this:
SCRIPT5: Access is denied.
File: embedViewer.html, Line: 1, Column: 1
WaylonLang
Thanks to those testing it out. The problem loading seems to be selective, affecting some but not others. Seen it here in the office as well. Might be a setting in IE or possibly an add-on causing problems. Will need to investigate further.
