Address data management of own database
620
11-27-2022 12:55 AM
NirdeshShrestha
How can I use address data management in ArcGIS map or ArcGIS pro when I have my own road network centerline, building footprints, entrance gate, and area coverage fence?
ThomasHoman
Hello @NirdeshShrestha ,
Looking at the solution deployment you can deploy to your ArcGIS Online instance. Once in place you could import your data in to the associated feature class via append so the solution could do the work.
You might need to some data review to determine if all your business need attributes fit or if the schema might need to be tweaked.
Hope this helps,
Tom
