Adding WMS service throws an error "WMS not accesible or doesn´t exist"
3463
10-24-2013 03:01 AM
DanaRe
I´m trying to add to the Portal ( 10.2 version) WMS services from other providers, everytime I tried it, the process finalize with an error: "WMS not accesible or doesn´t exist".
I add the same service through ArCcatalog, so I´m sure that the resource is available and running. The same happends with internal WMS resources.
(Arcgis  services accesed through REST directory works fine)
I´m wondering if I´m  missing something in the configuration , anybody else with the same problem?
Thanks!
KhairulAmri1
Hi dana,
Are you use proxy in your network ? I use previous version (2.1) and got same problem when i use proxy in network. to solve this problem, add proxy setting in portal web server
here is the configuration in 2.1 (use glassfish as webserver) :
path : glassfish3/glassfish/domains/domain1/config/domain.xml
<jvm-options>-Dhttp.proxyHost=yourproxy</jvm-options>
<jvm-options>-Dhttps.proxyHost=yourproxy</jvm-options>
<jvm-options>-Dhttp.proxyPort=yourproxyport</jvm-options>
<jvm-options>-Dhttps.proxyPort=yourproxyport</jvm-options>
<jvm-options>-Dhttp.nonProxyHosts=yourdomain</jvm-options>
<jvm-options>-Dhttps.nonProxyHosts=yourdomain</jvm-options>
however, 10.2 have different webserver (apache tomcat not glassfish). here is proxy setting in apache tomcat :
path:
Portal/framework/runtime/tomcat/conf/catalina.properties
add this setting:
http.proxyHost=yourProxyURL
http.proxyPort=yourProxyPort
http.proxyUser=yourUserName
http.proxyPassword=yourPassword
http.nonProxyHost=yourdomain
https.proxyHost=yourProxyURL
https.proxyPort=yourProxyPort
https.proxyUser=yourUserName
https.proxyPassword=yourPassword
https.nonProxyHost=yourdomain
make sure internet connection in your portal server is working
Amri
