Adding Post Code data by adding a layer from file
1815
6
06-06-2013 01:14 PM
SteveYetman
I am attempting to add some data that is referenced by post code. However, when I attempt to import the CSV file I get an error message when I try to locate feature by post code. The error message is as follows: An error occurred while creating features. (Generate Features exception 'null')
Thank you for your help.
Kind regards
Steve
MikeMinami
Esri Notable Contributor
can you share your CSV here?
Mike
SteveYetman
Thanks Mike
I can, it is just a simple trial csv, attached.
MikeMinami
I'm not sure if there was an error uploading the file, but it only has one record, the header record. Can you upload again?
Mike
SteveYetman
Thanks Mike
I have attached the file. I have had to zip it as it would not allow csv uploads and the txt file was too big.
Grateful for your help.
Kind regards
Steve
SteveYetman
Mike
Sorry, the last file had 1000 entries. The one attached has 50, which I believe should work.
Thanks
Steve
MeganPatent-Nygren
I am getting the same error.  My addresses all have standard US five-digit zip codes.  I would prefer not to share my data in a public forum.  I have 98 unique entries.  Thanks!  Megan
