Create / Edit Feature Time off by 4 Hours
1391
05-21-2013 06:32 AM
RichardCitkowicz
I have been searching but haven't found out how to change it. I understand the time in the browser is UTC based and when a feature is edited or created in the field the auto populated time and date are ahead by 4 hours. Where do I edit this UTC or where in ArcMap or ArcGIS Online do I change the default time to represent EST? Any help would be great!
MikeMinami
Esri Notable Contributor
How are you adding your data to the map?
What kind of layer are you using? A hosted feature service?
ArcGIS Online stores data in UTC. So any data you upload is assumed to be in UTC. When viewed in a browser, the browser will adjust the time to local time.
See if these posts help.
http://forums.arcgis.com/threads/34299-Web-Map-shows-wrong-quot-beach-sampling-date-quot-in-popup-wi...
http://forums.arcgis.com/threads/67212-With-popups-from-CSV-upload-Date-gets-bogus-time-stamp-Time-i...
Mike
RichardCitkowicz
Thanks for the links. These are the two I came across when I was searching for a answer. It didn't fix the issue so I posted this here.
I am uploading a Point feature class from ArcMap 10.1 without a date edit and date created field and turning this on after the feature service is published.
