Adding new fields to hosted feature service
1138
03-19-2021 09:08 AM
LMSID
I have a hosted feature layer with multiple view layers created from it. I need to add new data to the hosted feature layer (new columns/fields). I get the data in .xlsx format, so need to use a join to attach to my hosted feature layer.
Is there an easy way to do this without disrupting existing symbology/WebApps/etc.?
jcarlson
MVP Alum
You're probably better of creating the new field empty and using a field calculation or python to populate its values.
Or even if you do the join and re-publish the main layer, add the new field first. We've had hosted layers where a republish with new fields doesn't correctly update the view layers, and the new field isn't accessible on the views.
- Josh Carlson
Kendall County GIS
jcarlson
MVP Alum
- Josh Carlson
Kendall County GIS
