Adding FEMA FIRMette Tool to my Arcgis online
2577
08-10-2016 05:22 PM
KathleenWallis
I have had a link to FEMA's flood plain map in my ArcGIS maps for about a year. Today when I opened the FEMA published Flood Plane map it says that a new National Flood Hazard Layer Print Tool is available.
The link goes to a great map (see link below) that has a print tool.
ArcGIS Web Application
I assumed that I could add this url for the FEMA print tool to my ArcGIS online map, however since it is not a https it does
not let me add it to my items. Does anyone know. Can I add this print template to my AGOL map or do I have to build my
own print template.
Thanks !
Katy
LeoLadefian5
Hmm, If you dig down into the services directory you can locate the print service, but it's actually a map server layer:
FIRMette/NFHL_Print (MapServer)
You need to find the Export Web Map task url and add it to your print widget.
LeoLadefian5
KathleenWallis
Got it !. Looks like I probably will not be able to utilize their print template because our services are https and FEMAs is http but thank you
for pointing me in the right direction.
