Add tile layer?
1503
03-22-2013 03:54 AM
MichaelScott
A little help on the adding a tile layer?
The example given in the blog post announcement (http://blogs.esri.com/esri/arcgis/2013/03/21/whats-new-arcgis-online-march-2013/) loads an opencyclemap.org layer file, but the details don�??t give the URL used so we can�??t model our own from it.
The prompt when adding the layer file suggests the syntax should be: http://{subDomain}.domain.com//{level}/{col}/{row}.jpg
But the only URL I can find from Open Cycle Map is one that�??s formatted like: http://opencyclemap.org/?zoom=2&lat=36.33194&lon=3.84092&layers=B00 which does�??t work�?�
I�??d actually like to load a MapBox tile layer, but the URL syntax seems wrong also. For example, the direct URL to my map is: http://tiles.mapbox.com/hobie888/map/test4 and the embed URL is http://a.tiles.mapbox.com/v3/hobie888.test4.html#14/38.886799999999994/-75.8277 Neither of these seems formatted correctly for an AGOL WebMap.
Thoughts?
by Anonymous User
Not applicable
What's the extent and projection of your map?
I was able to add this layer from map box.
http://api.tiles.mapbox.com/v3/examples.map-d40qac29/{level}/{col}/{row}.png
Cheers,
Andrew
