Add subtype to Hosted AGOL Layers in Hazard Reporting Solution?
733
08-18-2020 08:46 AM
by Anonymous User
Not applicable
I am attempting to configure the Hazards Reporting Solution that ESRI has for our Emergency Operations Center.  I added two fields "Product Type" and "Product" to the Hazards layer.  I need to make the Product Type field a subtype for Product so that when staff in the field are recording a spill they select "BioHazard" from Product Type and then only see the BioHazard domain coded values list for them to choose, not all 50 options but then just the 5 options.  Using Pro "Create/Manage Subtypes" is greyed out.  In AGOL or Developers AGOL, I can't see a way to assign or define the subtype for use in Collector.  Any help or guidance would be much appreciated!
