Add fields from another datasets Arcade
4564
10
09-16-2021 06:40 AM
AdrianPatrulescu
var features = FeatureSetByPortalItem( Portal('https://www.arcgis.com'), '98cca0ba2d58470b96061faa24421e66', 0, ['ID_FCC', 'RestorationArea','RestorationType','Project','HabitatRestored','Date'], false );
var filterFeatures = Filter(features, "RestorationType <> 'Riparian'");
var distinctFeatures = Distinct(filterFeatures,['ID_FCC','RestorationArea']);
return distinctFeatures
The above feature set return only unique  combination between ID_FCC  and RestorationArea (witch is what I want) columns together with ROW_ID
But I want to return also the fields from FeatureSetByPortalItem (eg 'RestorationType', 'Project', 'HabitatRestored' and 'Date')
Apparently Distinct Function remove other columns
Is there a way to rejoin all the fields base on ROW_ID?
Adrian
AdrianPatrulescu
Yes you are correct i need "129.12" instead of "152,68"
But in the dashboard I have another Indicator which make a sum of the RestorationArea (including duplicates) called Reforestation effort. I need both sums (including and excluding duplicates) in one dataset
On the other hand the other columns like species:fir(BR), spruce (MO), beach (FA) ...... they must be added regardless of RestorationArea duplicates
