Creating an Email Trigger for a non Public Feature Layer with Power Automate
799
09-29-2021 12:14 PM
AustinWolf1
Hi Everyone,
I recently created a flow through Power Automate based on the guide below that sends out an email whenever a new polygon is created in an ArcGIS Online feature layer:
https://www.esri.com/arcgis-blog/products/field-maps/field-mobility/use-webhooks-to-automate-workflo...
Everything worked well until I decided to change the sharing status of the layer from Public to the Organization level. The flow now stops working at the "Check Status" step, within the "Check Status Until Ready" loop. My configurations are the exact same as this guide. It appears that this step requires a token that isn't being created. Is there anything I can do to fix this issue?
Thank you! If you need more information, I'll gladly answer any comments.
