Add account from another Organization to Ours
386
04-07-2025 11:43 AM
MeleKoneya1
Good morning,
I was instructed to do this to add an user in another org, myself, to our AGOL orgnanization.
"You will need to get your mkoneya_xxx account added to the Scottsdale AGOL Org"
It was not clear how to do it so I thought I would check here.
Which option do I use when inviting members?   Do I create a group and add users?
Thank you,
Mele
DavidColey
MVP Frequent Contributor
Hi @MeleKoneya1  - yes you will want to create a group and then add users.  For example, for esri support in our org, I created a group titled EsriSupport and then made sure for:
'Who can be in this group?'
Check the:
Any organization's members
toggle
Then all you need to do once the group is set up is to go to the Invite Members and toggle for the:
"Search all ArcGIS Online organization members" as the search criteria and add the user_name that should be provided to you if you are the one doing the 'adding to'.
Hope this helps-
David
