Accessing SDE on ArcGISonline.com
3135
12-01-2011 06:29 AM
SeanConner
Is it possible to publish a map onto ArcGISonline.com containing data from an SDE service containing point features?  If so, what steps must be taken to accomplish this?
SeanConner
The data does not need to be edited, just accessed online via a password protected group for reference.
MikeMinami
Esri Notable Contributor
You need to host it on ArcGIS Server. Alternatively, if it's a small dataset, you could export to CSV or shapefile and load it over the map. From the ArcGIS.com Map, click Add, then add data from file.
Mike
