Spatial Analisys Tool question
3016
10
08-18-2021 09:20 AM
Status: Open
alejocasf
Hi.
Thanks for this community. I'm looking for a tool in which with a groups of different data layers. You can combine and ponderate them. The final product is a map with the ponderation and a new all set of layers with the info we are looking for ans answer.
I'm trying to know the name of this tool...
Thanks in advance.
Best Regards
10 Comments
DavidPike
Possibly Merge https://pro.arcgis.com/en/pro-app/latest/tool-reference/data-management/merge.htm
As to ponderate, that's probably a mistranslation as I have no idea what you mean.
RPGIS
by MVP Regular Contributor
As @DavidPike said, the merge tool is you best option.
alejocasf
Hi. Thanks for your reply. The word is weighing.
alejocasf
What I want ifrom the software creates new areas or layes analyzing others data sources as other layers, or images...
DavidPike
I don't understand you at all sorry.  good luck.
alejocasf
I know that what I'm looking for is like make a sum from let's suppose 3 layers. But from my point of view layer 1 has a percentage over the final solution of 50%. And the other two layers can be 25% each one.
Then the software analyze this sources and calculates a new layer with the answer.
alejocasf
The word is
Weighting
alejocasf
Thanks a lot.
Do you think I can do something like that but with vector data????
AmandaRing
Depending on your workflow, you could potentially add numeric fields to each layer with the desired weighting value, then use Overlay Layers - Intersect for successive pairs of input layers/results. Once all have been combined, create a new field and use Calculate field to combine the weightings as desired.
But the best approach would probably be to use the Feature to Raster tool and then perform a Weighted Overlay of those newly created rasters.
