Show Results from Query Widget in Attribute Table Widget (Web App builder widgets)
2888
02-04-2015 07:18 AM
Status: Open
DavidWhite2
ArcGIS Online Web App builder offers a query widget to select by attributes.  The query widget offers the option of displaying the results as an operational layer on the map.  The enhancement would be to make this "operational layer" available to the attribute table widget.  The attribute table widget appears only to support interactive selections at this time.  Having the query results visible in the attribute table widget would allow a user to view, sort  and export the records they have already selected via the query widget.  The attribute table widget appears to only allow one to filter by extent, and to select rows interactively.
2 Comments
PatrickMcColley
Great Idea
StanMcShinsky
When you make a selection using the Query tool you can check the box to make the result an operational layer. When that happens it adds the query result to the Layer List widget. There is a drop down arrow to the right of the layer name that onece clicked you can select to "Open Attribute Table". You can open the results in the attribute table and work from there.
