Export to Mobile Geodatabase
856
04-15-2021 03:24 PM
Status: Open
GregWyatt
I would like to see ArcGIS Online allow layer export to the new Mobile Geodatabase format.
1 Comment
CorrineR
Second this.  From the hosted layer item details page in AGOL, there is not an export to Mobile Geodatabase option.
A possible workaround is to add the hosted layer to a map in ArcGIS Pro, and if exporting is enabled on the service, you can right-click the layer from the Content pane > Data >Export features. This approach should copy over geodatabase behaviours such as subtypes and domains. However, it does not copy over the relationship class and related table.
If migrating relationship classes is needed, then a different workaround could be to Export the hosted layer to FGDB and then use the copy/paste method or other supported GP tool to migrate back to a mobile geodatabase.
