Enable viewing and changing the coordinate reference system (CRS) of Web Maps in ArcGIS Online
1700
06-11-2025 04:59 AM
Status: Open
LadislavJeník
As a regular user of ArcGIS Online and Experience Builder, I often work with spatial data in different coordinate reference systems – especially WGS84 (EPSG:4326) and national systems such as S-JTSK (EPSG:5514).
Currently, the coordinate system of a Web Map is implicitly set when the map is first created (based on the basemap or first operational layer). After that, there is no user-friendly way to view or change the map’s CRS, which causes multiple challenges:
Problems:
  • The CRS is invisible in the Map Viewer interface – users cannot easily determine what coordinate system is being used.
  • Even if the basemap is later replaced with one in WGS84, the Web Map may still retain a custom projection (e.g., S-JTSK), causing:
    • Skewed rendering,
    • Slow drawing performance (due to reprojection),
    • Poor compatibility with other apps like Experience Builder.
  • Editing the CRS requires manual modification of JSON via ArcGIS Assistant – a risky and non-intuitive process.
  • ArcGIS Pro allows changing the map’s projection locally, but this does not propagate back to the original Web Map in AGOL.
    Proposed improvements:
    1. Show the current CRS in the Map Viewer (Classic and new).
    2. Allow users to change the spatial reference of existing Web Maps, e.g.:
      • Through map settings,
      • By reinitializing based on a new basemap or user selection.
    3. Warn users when projections between layers and the map differ, and offer to reproject or recreate map in another CRS.
    4. Make this functionality available both in ArcGIS Online and ArcGIS Pro publishing workflows.
    5. If limitations apply, provide clear guidance or suggestions via the UI (e.g., when mixing projections).
    Why this matters:
    • It would prevent common confusion and wasted hours trying to “fix” reprojection artifacts.
    • It would empower users to optimize performance and ensure accurate spatial display.
    • It aligns with how GIS professionals work in ArcGIS Pro, where CRS control is standard.
    • It reduces reliance on advanced JSON editing, which not all users are comfortable with.
3 Comments
MarcelBeckmann
We have the same problem. So anoying that there is no easy way to just see the coordinate system of the webmap.
Hopefully this will be implemented soon.
FrancisUWHuskies
I totally agree! This especially comes into play when using drone imagery that is collected in a local coordinate system and then published to Portal as an image layer. I believe there is a recent change to Enterprise 12.x where if you publish an imagery layer in say, State Plane and then want to add it to an existing map in Web Mercator, it gives you an error that it cannot be added to the map. Projections on maps and layers should be visible easily, preferably in the properties pane in map viewer.
AnnaHradecká
Same for me. I have default basemap in local CRS and it is every time hard to change to one with Web Mecator.
