Allow MFA QR Code to be displayed after initial set up
1718
12-20-2023 11:50 AM
Status: Open
Daniel_Perkins
Once a user has set up multi-factor authentication (MFA), there is no way for them to add another device in the future if they didn't save the QR code on initial set up. It would be good to allow the QR code to be generated again without involving an admin.
For example, you lose your phone and use a recovery code to login. At that point, you should be able to access the QR code to set up a new device.
@BernSzukalski I added this to a recent blog post you had but figured it might be better in Ideas. Thanks.
4 Comments
JenFrazer_USFS_NR-GISS-IRIN
The NIFC org is not the only organization that needs this to reduce administrator requests.
PaulHoefflerGISS
USFWS also requires this basic functionality.
NW-AjCorwinGISS
Yes!  This would be super helpful.  Some way to add additional devices!
Daniel_Perkins
Looks like this can now be done:
Assuming you can login to your account on a computer, but get a new phone and need to move the MFA to a new device.
My settings -> Security -> MFA -> Reset
You will then get a new QR code and recovery codes.
