Add option to remove zoom to and pan from popups
671
07-26-2024 07:39 PM
Status: Open
JeffShaw
Please add an option to remove the zoom-to and pan panel from the top of popups. They are rarely used and take up valuable space, especially on small devices. If a person clicks on a feature in a map to open a popup they have already zoomed/panned to the location. Or at least put them at the bottom of the popup.
Tags (3)
2 Comments
zibonvil
In the top when you are viewing someone's screen, click on the arrow kind of thing that bring's up a menu. The menu will be under the little green box that says, "You are viewing ___'s screen." There you will find an option called side by side mode. Enable it, and the talking thing will be gone. Also, it shouldn't be doing it with the new update. If you have the new update and it is still coming up, then in the top right, click the view button, and then click on one of the side by side options, either side by side gallery, or side by side speaker view. Hope this helps, please reply if you need more help/detail https://mobdro.bio/ . TIA!
JeffShaw
Hi @zibonvil I wonder if you intended to post your comment somewhere else. The interface options you mention don't seem to be related to ArcGIS Online webmap popups.
