Overwrite ArcGIS Online Feature Service using ArcGIS Pro Project
27561
46
01-17-2024 12:38 PM
Previously, I wrote an document on how to overwrite an ArcGIS Online feature service by referencing a feature class and using a truncate/append method.  I received a lot of feedback from this document, with some users encountering limitations such as attachments not being supported, and updating services containing multiple layers.  This solution is aimed to address these limitations.  Below is a script to overwrite an ArcGIS Online feature service by referencing an ArcGIS Pro project, and a video on how to use the script.  Please comment below if there are any issues or questions.
import arcpy, os, time, requests, json
from arcgis.gis import GIS
from arcgis.features import FeatureLayerCollection
# Variables
prjPath = r"C:\Projects\GeoNET\GeoNET.aprx"                 # Path to Pro Project
map = 'State Parks'                                         # Name of map in Pro Project
serviceDefID = '3fa1620c47dc490db43b9370e8cf5df8'           # Item ID of Service Definition
featureServiceID = 'fb42ef7b43154f95b8b6ad7357b7f663'       # Item ID of Feature Service
portal = "https://www.arcgis.com"                           # AGOL
user = "jskinner_rats"                                      # AGOL username
password = "********"                                       # AGOL password
preserveEditorTracking = True                               # True/False to preserve editor tracking from feature class
unregisterReplicas = True                                   # True/False to unregister existing replicas
# Set Environment Variables
arcpy.env.overwriteOutput = 1
# Disable warnings
requests.packages.urllib3.disable_warnings()
# Start Timer
startTime = time.time()
print(f"Connecting to AGOL")
gis = GIS(portal, user, password)
arcpy.SignInToPortal(portal, user, password)
# Local paths to create temporary content
sddraft = os.path.join(arcpy.env.scratchFolder, "WebUpdate.sddraft")
sd = os.path.join(arcpy.env.scratchFolder, "WebUpdate.sd")
sdItem = gis.content.get(serviceDefID)
# Create a new SDDraft and stage to SD
print("Creating SD file")
prj = arcpy.mp.ArcGISProject(prjPath)
mp = prj.listMaps(map)[0]
serviceDefName = sdItem.title
arcpy.mp.CreateWebLayerSDDraft(mp, sddraft, serviceDefName, 'MY_HOSTED_SERVICES',
                               'FEATURE_ACCESS', '', True, True)
arcpy.StageService_server(sddraft, sd)
# Reference existing feature service to get properties
fsItem = gis.content.get(featureServiceID)
flyrCollection = FeatureLayerCollection.fromitem(fsItem)
properties = fsItem.get_data()
capabilities = flyrCollection.manager.properties
# Get thumbnail and metadata
thumbnail_file = fsItem.download_thumbnail(arcpy.env.scratchFolder)
metadata_file = fsItem.download_metadata(arcpy.env.scratchFolder)
# Unregister existing replicas
enableSync = False
if unregisterReplicas:
    if flyrCollection.properties.syncEnabled:
        enableSync = True
        print("Unregister existing replicas")
        for replica in flyrCollection.replicas.get_list():
            replicaID = replica['replicaID']
            flyrCollection.replicas.unregister(replicaID)
# Overwrite feature service
sdItem.update(data=sd)
print("Overwriting existing feature service")
if preserveEditorTracking:
    pub_params = {"editorTrackingInfo" : {"preserveEditUsersAndTimestamps":'true'}}
    fs = sdItem.publish(overwrite=True, publish_parameters=pub_params)
else:
    fs = sdItem.publish(overwrite=True)
# Update service with previous properties
print("Updating service properties")
item_properties = {"text": json.dumps(properties)}
fs.update(item_properties=item_properties)
flyrCollection.manager.update_definition(capabilities)
# Update thumbnail and metadata
print("Updating thumbnail and metadata")
fs.update(thumbnail=thumbnail_file, metadata=metadata_file)
print("Clearing scratch directory")
arcpy.env.workspace = arcpy.env.scratchFolder
for file in arcpy.ListFiles():
    if file.split(".")[-1] in ('sd', 'sddraft', 'png', 'xml'):
        arcpy.Delete_management(file)
endTime = time.time()
elapsedTime = round((endTime - startTime) / 60, 2)
print(f"Script completed in {elapsedTime} minutes")
Updates
Update 2/2/24:  Added the option to unregister existing replicas
Update 12/2/24:  Sync is re-enabled if it was previously enabled
Comments
ModernElectric
@JakeSkinner
This version is working great. Been working with it all week on my electric and water dataset(s). All of my relationship classes stay intact and the attachments are all loaded after running the script. Will continue to work with it and develop my update workflow and let you know if I run into any new issues or bugs.
As of now, the Hosted Feature Layers are used in a web map being used in Field Maps. We are also using ESRI Workforce for our field crews and those maps/datasets need to have sync enabled, I am curious on adding those feature layers to some of our Workforce Projects and seeing how this update procedure works.
Appreciate your help!!
KatGIS
Hi @JakeSkinner,
Thank you so much for this updated script!
It's exactly what we have been attempting to keep sync enabled and not break the replicas, and also overwrite the HFL with attachments.
Unfortunately I am running into an issue once testing it with an offline layer in Field Maps. The script runs perfectly before adding it to Field Maps (I believe before creating any replicas?).
But in the "Overwrite Feature Service" block, I receive this error:
KeyError                                  Traceback (most recent call last)
In  [65]:
Line 9:     fs = sdItem.publish(overwrite=True)
File C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\gis\__init__.py, in publish:
Line 12740: elif not buildInitialCache and ret[0]["type"].lower() == "image service":
KeyError: 'type'
I removed the replica by removing it from Field Maps, and tested the script again and it still works.
We have field workers offline for days at a time, so this is a roadblock.
The script is the same besides the fact I must sign into AGOL through Pro gis = GIS("pro") in order to bypass mandatory Multi-Factor Authentication.
Any idea how this error could be resolved?
Greatly appreciate your help! 🙂
DJB
@JakeSkinner
I've been using very similar code to overwrite service on a nightly basis.  Up until this morning it has been working great.  I now get a warning that item.share has been deprecated and that I now need to use item.sharing.
DeprecatedWarning: share is deprecated as of 2.3.0 and has be removed in 3.0.0. Use `Item.sharing` instead.
I'm having a hard time following the documentation that describes the new sharing module.
If you have any suggestions or material that outlines how to update the sharing to everyone I would greatly appreciate it.
I did find an example where the sddraft XML is altered but that seems like a step backwards and requires a lot more code for what use to take just a couple lines of code.
# Read the .sddraft file
docs = DOM.parse(sddraft_output_filename)
key_list = docs.getElementsByTagName('Key')
value_list = docs.getElementsByTagName('Value')
# Change following to "true" to share
SharetoOrganization = "false"
SharetoEveryone = "true"
SharetoGroup = "false"
# If SharetoGroup is set to "true", uncomment line below and provide group IDs
GroupID = ""    # GroupID = "f07fab920d71339cb7b1291e3059b7a8, e0fb8fff410b1d7bae1992700567f54a"
# Each key has a corresponding value. In all the cases, value of key_list[i] is value_list[i].
for i in range(key_list.length):
    if key_list[i].firstChild.nodeValue == "PackageUnderMyOrg":
        value_list[i].firstChild.nodeValue = SharetoOrganization
    if key_list[i].firstChild.nodeValue == "PackageIsPublic":
        value_list[i].firstChild.nodeValue = SharetoEveryone
    if key_list[i].firstChild.nodeValue == "PackageShareGroups":
        value_list[i].firstChild.nodeValue = SharetoGroup
    if SharetoGroup == "true" and key_list[i].firstChild.nodeValue == "PackageGroupIDs":
        value_list[i].firstChild.nodeValue = GroupID
This is how I use to do it.
# Set sharing options
shrOrg = True
shrEveryone = True
shrGroups = ""
if shrOrg or shrEveryone or shrGroups:
    print("Setting sharing options…")
    fs.share(org=shrOrg, everyone=shrEveryone, groups=shrGroups)
Thank you
JakeSkinner
Esri Esteemed Contributor
@DJB you can update the sharing with the following:
from arcgis.gis._impl._content_manager import SharingLevel
sharing_mgr = fs.sharing
if shrOrg:
    sharing_mgr.sharing_level = SharingLevel.ORG
if shrEveryone:
    sharing_mgr.sharing_level = SharingLevel.EVERYONE
if shrGroups:
    for groupID in shrGroups:
        group = gis.groups.get(groupID)
        item_grp_sharing_mgr = sharing_mgr.groups
        item_grp_sharing_mgr.add(group=group)
I did notice if the sharing is already set on the feature service, you can omit this entirely and it will be maintained.  I can't recall if it use to do this or not at earlier versions of the API.
DJB
@JakeSkinner
Thanks for the assistance Jake.  I wasn't aware that when overwriting a feature service it will still honour the original sharing properties.
I will definitely use this new code for when I need to alter sharing properties in the future.
Thanks again for your help Jake.  Cheers!
cjenkins_rva
Frequent Explorer
Hi @JakeSkinner, thanks very much for sharing this. Unfortunately, when I run the script, my symbology and pop-up configurations (both having been defined in the Visualization tab) are not preserved. I believe that's happening because that info is stored at the portal item level, not at the service level, so they aren't captured in existingDef (they would have be to grabbed via fsItem.get_data()). But in your video, I see these properties are preserved. I can't figure how that's possible. What am I missing?
KristalWalsh
Hi @JakeSkinner thank you for this! I am not a programmer but I tried this and am getting what seems to be a sign-in to portal error. Do you know if anyone else has had this problem? I know I'm using the correct user name and password. I am using AGOL not Enterprise so this should be pretty straightforward I think. Thank you, Kristal
JakeSkinner
@KristalWalsh do you know if you are using a built-in AGOL account?  Or, are you using a SAML user account?  With SAML, there is an icon you can click that will sign you in using the same account you typically sign into Windows with.
KristalWalsh
@JakeSkinner hi, thank you, I have an organizational account for a government agency so not sure if that is considered "built-in". I am signed in to my AGO account in another window not that it makes any difference.
JakeSkinner
@KristalWalsh is there an '@' symbol in your username?
KristalWalsh
@JakeSkinner no, not in the body of the code where my user name is inserted. I followed your video exactly.
KristalWalsh
@JakeSkinner I noticed earlier that I was not signed in to Pro. I thought maybe I got disconnected at some point, so I just ran it again after signing in to Pro. It seems that when I execute the script, it signs me out of Pro. Should that happen?
JakeSkinner
@cjenkins_rva I'm not sure if something changed in the API or not, but I swore this was working before.  However, I updated the code to use the .get_data() and apply this to the service using the requests module.  I couldn't find a way via the API to apply the properties all at once for all layers; that functionality may not exist, yet.  Anyways, give the updated code a try.
ModernElectric
@JakeSkinner
Been using the latest script to rebuild my update workflow.
On one of my Web Maps/Hosted Feature Layers - using this updated script - why am I getting:
mp = prj.listMaps(map)(0)
IndexError: list index out of range
JakeSkinner
@ModernElectric do you have the name of the map in ArcGIS Pro specified correctly for the map variable?
ModernElectric
Disregard.
Please forgive my ignorance, lack of proof-reading abilities 😉
Updated Script is working perfectly for updating our AGOL dataset.
cog_GIS_Admin
This script seems to be just what I am looking for, but I get an error when trying to login to AGOL.
Connecting to AGOL
File "E:\Scripts\Workorders_CD\NewOverwriteWebLayers.py", line 30, in <module>
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\__init__.py", line 2609, in SignInToPortal
return _SignInToPortal(*args, **kwargs)
ValueError: Error signing on to https://arcgis.com/.
Message : s
Details : Unable to generate token.
Any Thoughts?
cog_GIS_Admin
My post keeps getting marked as spam, not sure why. I'll try again. This script is just what I was looking for, but I am getting an error trying to log into AGOL.
Connecting to AGOL
Message : s
Any ideas?
JakeSkinner
@cog_GIS_Admin check the casing of your username, this is case sensitive.  For example, if your AGOL login is cog_GIS_Admin, and you specify cog_gis_admin, it will not authenticate.....even though cog_gis_admin will work in a web browser.
cog_GIS_Admin
Thanks Jake, that was the issue. Now working on getting it to auto run with the server task scheduler.
JakeSkinner
@cog_GIS_Admin here is helpful document on how use Windows Task Scheduler with python scripts:
https://community.esri.com/t5/python-documents/schedule-a-python-script-using-windows-task/ta-p/9158...
TomShewring
I am running this script with an internal Enterprise (Portal) with IWA.
The script is working for me up until 'Update service with previous properties'
File "<string>", line 81, in <module>
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\json\__init__.py", line 346, in loads
return _default_decoder.decode(s)
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\json\decoder.py", line 337, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\json\decoder.py", line 355, in raw_decode
raise JSONDecodeError("Expecting value", s, err.value) from None
json.decoder.JSONDecodeError: Expecting value: line 1 column 1 (char 0)
JakeSkinner
@TomShewring are you attempting to update a hosted feature service, or a referenced service?
TomShewring
Hi @JakeSkinner , a hosted feature service.
I have got the 'Update service with previous properties' working - I had to use the siteadmin (default Administrator) account when connecting to Enterprise (Portal).
I now have a error in the 'Clearing scratch directory' section. I do not have ArcGISPro open (I am running this script from the command line not from within ArcGISPro) - so I do not know what application could be locking the WebUpdate.sd?
File "E:\AGOL_Scripts\Geoprocessing\ScheduledTools\NHLEonPortal\updateNHLEonPortal2.py", line 102, in <module>
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\management.py", line 7665, in Delete
raise e
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\management.py", line 7662, in Delete
retval = convertArcObjectToPythonObject(gp.Delete_management(*gp_fixargs((in_data, data_type), True)))
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\geoprocessing\_base.py", line 512, in <lambda>
return lambda *args: val(*gp_fixargs(args, True))
arcgisscripting.ExecuteError: ERROR 000601: Cannot delete C:\Users\tshewring\AppData\Local\Temp\scratch\WebUpdate.sd. May be locked by another application.
Failed to execute (Delete).
JakeSkinner
@TomShewring I've seen this error occur sporadically in some implementations (mine included), and I'm unable to find a cause.  To workaround the issue, I recommend moving the Clear scratch directory section to the beginning of the script.  For example, move this section of code above the section that connects to AGOL/Portal.
TomShewring
@JakeSkinner , thanks - moving the 'Clear scratch directory' section to the beginning of the script, above the section that connects to AGOL/Portal - this works.
One further thing I don't understand is - I have to use the <portalurl>:7443/arcgis address. If I use the WebAdaptor address I get errors such as these (even though I am using the same username and password in each scenario) -
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\auth\_auth\_winauth.py", line 75, in __init__
creds = gssapi.raw.acquire_cred_with_password(
File "gssapi\raw\ext_password.pyx", line 75, in gssapi.raw.ext_password.acquire_cred_with_password
gssapi.raw.exceptions.BadNameError: Major (131072): An invalid name was supplied, Minor (2529639136): Configuration file does not specify default realm
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgis\auth\_auth\_winauth.py", line 84, in __init__
raise Exception("Please ensure gssapi is installed")
Exception: Please ensure gssapi is installed
Do you know why this is?
JakeSkinner
@TomShewring
  1.  Do you have Windows Authentication enabled on Portal's web adaptor?
  2. What version of Enterprise?
  3. What version of the arcgis api for python?
TomShewring
@JakeSkinner
1. Yes Windows Authentication is enabled on Portal WebAdaptor
2. Enterprise (Portal / Federated Server / Datastore) version 11.3
3. I have tried the script with
(i) ArcGISPro 3.3.1 -
and
(ii) ArcGISPro 3.1.4
JakeSkinner
@TomShewring try removing the username/password variables from the following lines:
These should not be needed if you Windows Authentication is enabled.  It will use the window's account that's signed into the server.
TomShewring
Hi @JakeSkinner , changing to these settings (and using the Portal WebAdaptor address) -
when I run the script from the command line I get a security challenge
So I could not run this as a scheduled task on the Windows server
JakeSkinner
@TomShewring this should not occur if you're running command prompt as a named user in Portal, and you have Portal's URL added to the Local Intranet (i.e. Start > Internet Options > Security tab > Local Intranet > Sites > Advanced > specify the portal URL (minus the web adaptor) > Add):
TomShewring
@JakeSkinner thats sorted it. Thanks.
Although we had deployed the Local Intranet change to all users, it had not been deployed on the server running the Overwrite (Portal) Feature Service script. Thanks for your help. Much appreciated.
Tharu20B
Wow!!
I learned lot of things from this. Thank you.
haksinguiliam
This is fantastic! 🙏
One suggestion to the recording, which by the way, did an excellent job of listing possible changes user like me would potentially make, is having a couple view layer created. I would assume using the script wouldn't disconnect view layer or receive any failed update error, but it would be comforting to see in the video.
SenadHodzicNR
@JakeSkinner  So reading through the script, no matter what you still need to disable sync to update the  feature service? Has anyone tested to see if their Offline Map Areas are preserved after this script is run?
ModernElectric
@JakeSkinner
Since I have last integrated this app into my update workflows, I have done a tremendous amount of development on our AGOL platform. The main dataset is maintained and edited on ArcGIS Pro from our internal server and updated to AGOL for usage in Field Maps, Survey123 and Workforce.
I have started including attachments to feature classes and related GDB tables with relationship classes.
One of the issues I have recently found is when I run the script and it updates a Hosted Feature Layer on AGOL (Feature classes, tables, relationships, etc), the data appears to be updated when I open the data dialog in My Content. However, when I open the map in Map View/Field Maps, the related tables are not reflecting the updates from the same Hosted Feature Layer. This is all from the python script.
When I run the tool in ArcGIS Pro to overwrite the hosted feature layer, the related tables in the Map Viewer do infact reflect the updated changes.
Any thoughts on the script you provided or something I am overlooking?
AndreaB_
Hi @JakeSkinner
I am running into this AGO bug, BUG-000171689, https://support.esri.com/en-us/bug/after-truncating-the-feature-layer-the-visibility-scale-bug-00017... "After truncating the feature layer, the visibility scale range of feature layer has been unexpectedly reset at the REST endpoint" when I run an ArcGIS Pro model that truncates and appends my hosted feature layer in AGO. So I thought I could use your script as a work around. Your script is great - but it still resets the visibility scale range for the feature layers in AGO.
visibility scale orig before overwrite.JPGvisibility scale after overwrite script.JPG
If I do a manual Overwrite Feature Layer using ArcGIS Pro - it keeps the visibility scale range for my layers. But I need to run this as a script nightly.
Are you able to add this to your code to keep the visibility range on the layers?
I'm not sure how else to work around this at this point.
***Edit - And.....nevermind. Your script works as a perfect work around and it does maintain the visibility range. I had unknowingly run the Model after your script so I had bad results.
Thank you!
A
JakeSkinner
Hi @AndreaB_, I could not reproduce this.  What version of ArcGIS Pro are you running?   I tested with ArcGIS Pro 3.6.1, which is version 2.4.2 of the arcgis module.
AndreaB_
Hi @JakeSkinner ,
Sorry for the confusion - I edited my post from last week. Your script is working great. I'm using ArcGIS Pro 3.5.5.
The bug, BUG-000171689, comes from ArcGIS Online and Esri tech support tells me the defect is currently under review with the development team.
But I'm using your script as a workaround to avoid that bug. Without your script I would be "cooked", as the kids say. 😊
Thank you!!
A
AndreaB_
Hi @JakeSkinner ,
The .py seems to run in Windows task scheduler because the item detail page in AGO says "item updated" with today's date. But the Last Run result in Windows Task Scheduler says 0x1.
Do you have any ideas?
A
AndreaB_
Hi @JakeSkinner ,
It looks like I spoke too soon about the script working. Even though the date shows updated in AGO my data isn't updated. I do have a View Layer created on this hosted feature layer. Do you think that's the problem? Here is what I get if I run the .py code in IDLE:
Python 3.11.11 (main, Mar  3 2025, 15:29:37) [MSC v.1938 64 bit (AMD64)] on win32
Type "help", "copyright", "credits" or "license()" for more information.
= RESTART: E:\Code\Overwrite Feature Service\Overwrite Feature Service.py
Connecting to AGOL
Creating SD file
  File "E:\Code\Overwrite Feature Service\Overwrite Feature Service.py", line 68, in <module>
  File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\arcgis\gis\__init__.py", line 16825, in publish
    return self._publish(**params)
  File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\arcgis\gis\__init__.py", line 17201, in _publish
    serviceitem_id = self._check_publish_status(ret, folder)
  File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\arcgis\gis\__init__.py", line 17563, in _check_publish_status
    raise Exception("Job failed.")
Exception: Job failed.
JakeSkinner
@AndreaB_ I could not reproduce this using Pro 3.6.1.  Could you publish another service, create a view, and test the script with the new service? This will determine if it's an issue with the script/API, or with the service.
AndreaB_
Hi @JakeSkinner ,
Thank you for testing it out. I just did some testing also with Pro 3.6.1. The issue is: the feature layer has a View Layer created with an Area of Interest defined within it.
When I create my View Layer in AGO:
This blocks overwriting of the feature layer. 🛑
Esri tech support has provided some links:
I am VERY surprised this is expected behavior. I would expect this to be a bug and functionality that needs to be fixed as soon as possible.
JakeSkinner
Thanks @AndreaB_ for reporting this back on the thread.  I was not aware of this limitation.
AndreaB_
@JakeSkinner You're welcome. It's not documented well anywhere. I'm waiting on more info from Tech support. I also found BUG-000115592 and Idea: https://community.esri.com/t5/arcgis-online-ideas/allow-overwriting-a-hosted-feature-layer-in-arcgis... Give it a Kudo please, everyone!
AndreaB_
One more post here to close the loop - The bug for this is indeed  BUG-000115592 and it's closed as a Known Limitation. The enhancement request is ENH-000179977 "Allow overwriting a hosted feature layer in ArcGIS Online when a joined view is present or a view with an area of interest is defined". It's In Review. And I'm hoping the documentation will be corrected to provide clarification on the known limitation. But most of all I hope with some Kudos on that Idea, Esri can implement this ability. Thanks.
Version history
Last update:
‎07-06-2026 07:33 AM
Updated by:
Contributors
