Token bloat
2099
09-21-2013 03:58 AM
RichardWatson
When you make calls to ArcGIS Online (and ArcGIS Server) you have to pass a token as a URL argument.  The problem with that is that tokens are large.  That is a problem because there is a magic size past which HTTP GET operations have to be converted to HTTP POST in order to avoid size limitations.
I was reading the following:
https://bugsnag.com/docs/api
The thing that is interesting here is the ability to put the token in the authorization header.  I am thinking that if ArcGIS * supported this then it would be more efficient because HTTP GET operations can be cached, i.e. more performant.
