Second login prompts while authenticating arcgis online with oAuth
9313
16
04-16-2015 03:55 AM
shafitrumboo
Robert Scheitlin, GISP​, Rebecca Strauch
Akshay HarsheMike Minami
I wanto to use Arcgis Portal and ArcGIS Server (10.3) but currently using arcgis online. I want for end users a custom home page where they will see all applications permitted to them.Rest for all I will user arcgis online like creating users, created apps and assigning apps to users.
I was successfully by going through OAuth Basic | ArcGIS API for JavaScript Am am to list only assigned application to signed in user but once I click on application it prompts me other login window again in attached image after screen 3.
I observed also if am  logged in in arcgis.com through user e,g agouser and when I access my application i,e localhost/portal/index.html my application prompts me that do want to access the application using that Id so
mminami-esristaff
AkshayHarshe
Sorry, Which image after screen 3? I can see just 3 images Screen 1,2 and 3.
Akshay Harshe
shafitrumboo
Oh Sorry!
AkshayHarshe
Are you logged in to the same browser window somewhere else?
Akshay Harshe
shafitrumboo
Same Browser window
KarenLandicho
Hi
Did you get a way around to solve this? I'm also trying to do this but still have no luck.
Karen
ChrisAdams
What if you access the application using the FQDN, i.e, machine.domain, instead of localhost?
PrevinWong1
From the different screenshots I see, you are accessing multiple domains (local host, *.arcgis.com).  Since these domains are different, they cannot access the authenticated session cookie of each other.  From screenshot 3, when you click on an application, are you prompted to login each and every time you click on an application from screenshot 3?
