I've developing a custom widget for Experience Builder, and I'm having issues implementing the Jimu Multiselect control, documented here: https://developers.arcgis.com/experience-builder/storybook/?path=/docs/components-jimu-ui-index-mult...
I can populate the multiselect with items, and I am capturing the item click event. What I can't work out, is how to set a default selection. When the multiselect is first opened, it looks like this:
And I want to be able to check some of these items by default, such as this:
I've tried implementing the 'defaultValues' property, but with no more than the very limited documentation provided by ESRI, and a storybook component that crashes when I click 'Set object' for this property, I have not been able to get this working:
Here's my code for reference (without any attempt to set default selection):
Appreciate if you can help me with this, as I'd quite like to use this Jimu component.
ESRI - Please improve your documentation for the Jimu component library, and for Widget development generally.
