how to get authentication to persist between apps
3669
12-12-2014 03:30 PM
ClintKellar2
I'm working on a gallery application that auto-populates content from a named user's organization content.
I started with the sample code here:
OAuth Popup | ArcGIS API for JavaScript
and modified it to only return web map applications.
I changed this original function:
function createGallery(items) {
var htmlFragment = "";
        arrayUtils
.forEach(items.results, function(item) {
          htmlFragment
"<div class=\"esri-item-container\">" +
                item
.thumbnailUrl ?
"<div class=\"esri-image\" style=\"background-image:url(" + item.thumbnailUrl + ");\"></div>" :
"<div class=\"esri-image esri-null-image\">Thumbnail not available</div>"
                item
.title ?
"<div class=\"esri-title\">" + (item.title || "") + "</div>" :
"<div class=\"esri-title esri-null-title\">Title not available</div>"
"</div>"
To this:
        arrayUtils.forEach(items.results, function(item) {
       if (item.type == "Web Mapping Application") {
              htmlFragment += (
                   "<a href='" + item.url + "' target='_blank'>" +
                   item.thumbnailUrl ?
                item.title ?
            "</div></a>"
The web map applications that are returned are either private to the named user logging in, or shared to the named user as a member of the organization.
The problem is, when I click on a hyperlinked app in the gallery, I am prompted again to login to the ArcGIS Online Organization. Anyone know of a way to get the authentication to carry over, when always hitting content in the same org?
