How to customzie an ArcGIS Online Web Viewer
2960
09-12-2013 09:43 AM
JoseSanchez
Hi all
I am looking for a web template where I can add customized code or set up the the following features:
??? Toolbar with the following buttons:
o Zoom in , Zoom Out, Pan, Zoom Full Extent, Previous Extent, Next Extent
o Select by Point, Select By Rectangle, By Polygon, by Circle,
o Buffer, Measure, Overview
o Find by address, Intersection
o Tracing, Printing, Help
??? Base map toolbar, shows custom maps instead of Esri base maps
??? Map section, shows map, overview window, loading map image, popup results window
??? Right panel
o Layers list, interactive when check/uncheck layer maps refreshes
o Legend
??? Multi search floating panel, search by address, intersection, folio, etc,
Could it be done adding JavaScript coce to the online template?
AllanLaframboise
If you "really" need to put all of that functionality into one single app, you could share out a number of templates and apps and then combine the source.  Or if you could just build a custom app with our ArcGIS JavaScript API.  The widgets will make things pretty easy.  If at all possible I would recommend building out smaller more focused apps.
AL
AllanLaframboise
Here's an example of a viewer with most of the functionality you are after.
https://github.com/DavidSpriggs/ConfigurableViewerJSAPI
AL
JoseSanchez
Hi Al,
What I do not understand is how do I run this template? Could it be load in ArcGIs Online and how, or does it run locally inside the enterprise intranet?
I can run int locally but the goal is to run it on the cloud (ArcGIs Online).
Thanks
AL
