Default polygon split method in Sweet for ArcGIS editing
660
12-19-2025 02:01 AM
Rune_Van_Severen
When editing polygons in Sweet for ArcGIS, splitting features is a common operation. In many real-world workflows—such as parcel editing, boundaries, or infrastructure—splitting a polygon by a line is the most frequently used method.
Currently, the default split option is “Split with polygon”, which requires users to manually switch to “Split by line” each time.
Question:
Is it possible in Sweet for ArcGIS to define “Split by Line” as the default polygon split method?
Why this matters:
  • Editing workflows are often repetitive
  • Line-based splits are the dominant use case
  • Reducing small UX frictions significantly improves editing efficiency
