Dashboard Chart Axis Display While Loading
1170
02-03-2025 03:13 PM
sandra555
I have a dashboard with a chart/graph. When the dashboard loads (which takes 5-6 seconds), the axes are expanded in the wrong direction and it looks unacceptably bad (attached). Two questions: Is there a way to make the chart load faster and is there a way to block the display and keep the spinning wheel until chart loading is completed? Thanks in advance.
sandra555
To solve this issue, I ended up changing the structure of my layers. I used a main layer that had one row for each location and included summary information (gauge and indicators) on the main dashboard. Then, I put the other layers in a separate dashboard and linked to it using a URL with a parameter. The main layer now loads quickly and the linked layer is prefiltered.
