Arcade supporting the font html tag
1078
06-02-2025 06:42 AM
JaysonLindahl
I'm using the font html tag and the color attribute to return colored labels.  I've read online that arcade supports this html tag.  Here is my script:
var pct = $feature.PCT_NO;
var label = "Precinct " + $feature.PCT_NO;
var color = when(
  pct == 1, "#FF0000",
  pct == 2, "blue",
  pct == 3, "green",
  pct == 4, "orange",
  "black"
return "<font color='" + color + "'>" + label + "</font>";
What is returned on the map is not colored text, but the actual html text in black.
Tags (1)
KenBuja
MVP Esteemed Contributor
Unfortunately, unlike ArcGIS Pro, you can't use formatting tags in a label in a web map. The way around that limitation would be to use a different label classes for each color.
For example, these labels were created using two label classes
The Deep label class uses the expression
if ($feature.Depth_ft > 30) return $feature.Depth_ft
while the Shallow label classes uses this expression
if ($feature.Depth_ft <= 30) return $feature.Depth_ft
KenBuja
