Aliases don't work in Arcade
804
07-09-2024 06:40 AM
N0MAD
Howdy
I have a problem with aliases, I changed the alias of a field like this:
But when i try to use the field in an arcade expression, the alias seems to don't work
For instance, when i call this field, here what's Arcade see:
var fields = Schema($feature).fields
Console(fields[42])
var count = 0;
for (var field in $feature) {
	if (count==41) Console(field)
	count++
Console:
{"alias":"T2_C9_POUSSIER_WINSBACK_MARIE_AGNES","defaultValue":null,"editable":true,"name":"T2_C9_POUSSIER_WINSBACK_MARIE_A","nullable":true,"type":"esriFieldTypeInteger"}
It seems that the field alias isn't stocked in the schema, but then, how can i get the aliases ?
jcarlson
That's really strange. It must be a field setting in the map? If the actual alias key in the schema doesn't have the preferred text, I don't know where else the popup would find it.
Do you have access to the source data? Configuring the aliases on the layer's Data tab would probably address this. If not, you might have to re-code the field names yourself using Decode or something.
- Josh Carlson
Kendall County GIS
