AGOL pop-up is not highlighting polygon features
6134
11-20-2015 12:02 PM
DamonMyers
For one specific feature layer in my AGOL web map, clicking on a feature in the layer will not highlight the selected feature even though the pop-up still functions normally. It is only this layer that the problem occurs with, as others in the same web map are still functioning properly. Can anyone provide any insight into why this might be happening?
A web app with the problem can be found here: http://gis0.odessa-tx.gov/public/internet/
Zoom in and try clicking on a parcel polygon to recreate the issue.
I have tried:
  • Removing and adding the layer to the map again.
  • Removing popups from the layer and adding them again.
  • Republishing the web service for the layer.
All to no avail.
Thanks in advance for any help,
Damon
RobertScheitlin__GISP
Damon,
   Your layer:
Layer: Midland County Appraisal Parcels (ID: 2)
Does not have the shape field visible thus it can not draw the geometry.
RickeyFight
I would move this question to Web AppBuilder for ArcGIS
DamonMyers
Are the pop-ups contained within the Web App Builder or to the Web Map in AGOL? I figured that because I configured the pop-ups in AGOL the configuration for them was stored with the AGOL map, rather than the WAB app.
Damon,
   You are correct they are stored in AGOL, so this is an appropriate location for this question.
Damon,
   Your layer:
DamonMyers
Robert,
That field must have gotten disabled in the shared MXD that we use for publishing our services. Thanks a ton, it is all functioning properly again.
Damon
