Where did Notebooks in AGO go?
I could work with AGO notebooks in 2019, now this option is gone from the menu, notebooks are still available as content items but cannot be opened ...
Any hints / pointers / solutions are much appreciated!
@Josef Strobl - did an administrator change your privileges maybe?
Notebooks require a new privilege which will hide the menu option if not available.
thanks for your quick response!
Well, I am the administrator, and there were no changes applied around the turn of the year.
When I 'Edit role', there is no 'Create and edit notebooks' option anymore ...
Josef,
Can you share your Subscription ID.
Nikhil,
7901565169 ... from what I have learned in the meantime: my access might have been based on a beta, which was superseded and thus removed (?) by the license renewal on Jan 1.
thanks, Josef
Josef,
Notebooks in Online is still in Beta.
Did you have a new AGO org. spun up when your license renewed? If so, then the new Sub ID would need to be white listed for Beta access as well.
I'm following up with our account team on the status for Sub ID:- 7901565169
Josef,
Can you check now. I believe it should be resolved and your Beta access has been extended.
Dear Nikhil,
thanks for quick action – works great!
Josef
Hi Nikhil,
We ran into the same issue since the renewal of our Esri France organization subscription (december 20, 2019), could you reactivate the beta version of Notebook on our portal (ID: 3223798461)
Thanks for your help...
Regards,
Gaëtan Lavenu
Hi Gaëtan Lavenu,
This should be resolved for your org.
