Notebook Server License Authorization (Silent Installation)
3050
11-25-2019 07:43 AM
Taladi
Hi All,
Is there any way to authorize Notebook Server with just license code ECPXXXXXXXX itself, Instead of license file?
I am trying trying on AWS Instance with Linux . Moreover as per ESRI Silent Installation Instructions (Silently install ArcGIS Notebook Server—ArcGIS Notebook Server Installation Guide (10.7) | ArcGIS En...),
I can't find any "Setup" file inside the ".gz" to run the above command. Correct me If I am wrong.
Anyone succeeded in silent Installation method? Suggest me on this.
Thanks in advance.
BenTurrell
Hey Venkat,
To do a silent install you will need a .prvc file which is based on an ECPXXXXXX number. To get one of these you will need to login to My Esri
Once you have logged in click on My Organization -> Licensing
License ESRI Products:
   Product: ArcGIS Enterprise
   Version: 10.7-10.7.1
   License Type: ArcGIS Server
   Licenses: Server licensing roles only
Click Next
Tick on the Notebook license you want to generate the file for. Click Next
Fill in your details on the next page. Click next.
Finally select how you would like to recieve your file (email or download)
You can then upload the afile to your ec2 and use it as part of your install.
Now for the install itself once you have unzipped the directory if you "cd" into the directory it unzipped to you should be able to see the Setup file using "ls"
If the tar folder is in your home directory you would do something like so
tar -zxvf ArcGIS_Notebook_Server_Linux_1071.tar.gz
cd ArcGIS_Notebook_Server_linux_1071
ls
The above will unzip and navigate to the folder and show all the files in the root of the Notebook install directory. You should then be able to run your install command.
Let me know if any of that doesn't make sense!
Thanks
Ben
BenTurrell
Hey Venkat,
Click Next
ls
Thanks
Ben
by Anonymous User
Not applicable
I have installed and configured in our enterprise environment and I will do with silent installation.
need any help let me know
