Maintain count variable between scheduled notebook tasks?
1630
12-07-2023 03:38 PM
ChristopherCounsell
MVP Frequent Contributor
Have an ID field with a mix of string and integer values.
I'd like to run a scheduled notebook to update the ID field with the next highest available integer id.
There's some obvious issues doing this with a string field containing string values. I'd like to avoid processing the field to identify the current highest ID each scheduled run.
Is it possible to set a count value, increment it for new features, and then have the current highest value persist between each scheduled notebook task?
i.e. count = get highest integer value in field (once)
count = 1000
scheduled task runs over a few features, count = 1003
next time the scheduled task runs, count = 1004
BobBooth1
You could save the current value in a text file in the notebooks files\home folder at the end of each run, and read it at the beginning of the next one.
BobBooth1
ChristopherCounsell
Thanks, worked a treat
