Execute shared AGOL notebook
1592
7
07-15-2025 05:06 AM
RichardHowe
A recent bug introduced with the latest API means that I have had to incorporate part of a Pro-based team script into an ArcGIS Online notebook. Quite aside from the frustration of having to code round the issue, this has now been compounded as it seems that the execute_notebook function in the API only allows you to run notebooks that the individual owns! My team all have the "Create and edit notebooks" ability in their AGOL accounts enabled, and the notebook in question is shared with them, but the script fails when it tries to execute the referenced notebook as they are not the owner. Is this really the case?
I would ask what use having the sharing option for notebooks is if another user can't execute it via code?
If this is by design/a major oversight please can we get it fixed? Or at the very least have an option for collaboratively owned notebooks?!
Alternatively, if I've got this wrong in any way or am misunderstanding, then any advice on making the process work would be gratefully received!
ChristopherCounsell
MVP Frequent Contributor
Users with that privilege should be able to run a notebook shared with them.
I would check:
  • Sharing level of content within the notebook
  • If there is a reliance of the script on ownership e.g. using GIS(home) and then derived usernames
  • If the notebook uses advanced runtime; this is an additional privilege
More info here:
https://doc.arcgis.com/en/arcgis-online/share-maps/share-a-notebook.htm#ESRI_SECTION1_9A95DCAD34F547...
RichardHowe
@ChristopherCounsell Thanks for confirming. I do use:
gis = GIS("Home")
in the notebook. What would be my alternative to make is usable by the users it was shared with
ChristopherCounsell
It shouldn't stop you from running the notebook.
It's more, does your python script rely on logging in as the content owner. Can't tell without the whole script.
If you can't even run the notebook this is not your issue
RichardHowe
Hi @ChristopherCounsell just returning to this issue now I have a bit of time to spend on it. This is the error we're getting:
{'code': 90030, 'message': 'The current user is not the owner of the notebook item, and updating the notebook item is not allowed.', 'messageCode': 'NBO_90030', 'details': []}
It's quite correct. The user is not the owner of the notebook item. However they do have a role in AGOL which permits "create and edit notebooks" and the notebook item is shared with them.
Quite aside from which I can't see any step in the process which actually needs them to "update" it anyway...it just needs to execute.
Just wondering if you had any further thoughts?
ChristopherCounsell
You can't update notebooks owned by other users. Need to be the owner.
There is something in your notebook that is trying to update the notebook when it is run. It might be a cell, storing the output, or changing files. Hard to say without seeing the notebook.
RichardHowe
Ah good tip, thanks. I will review it. Could it be as simple as a print statement?
ChristopherCounsell
I'd assume it's the workspace, other users can't access it at all. Need to
use items.
