AGOL : python lib install in jupyternotebook with pip
3899
7
07-16-2024 01:25 AM
DISIG
Hello everybody,
I am tring to install this python lib.
i am using jupyternotebook on arcgis online
when i run this code
%pip install yfiles_jupyter_graphs --quiet
from yfiles_jupyter_graphs import GraphWidget
i have got this message
DEPRECATION: Loading egg at /opt/conda/lib/python3.11/site-packages/tflite_model_maker-0.3.4-py3.11.egg is deprecated. pip 24.3 will enforce this behaviour change. A possible replacement is to use pip for package installation.. Discussion can be found at https://github.com/pypa/pip/issues/12330
Note: you may need to restart the kernel to use updated packages.
how can i Avoid this?
fskpf
Maintainer of yfiles-jupyter-graphs here.
Just yesterday, we fixed an issue with our CDN deployment which made VSCode fail to load the widget (https://github.com/yWorks/yfiles-jupyter-graphs/issues/54).
I'm not familiar with how AGOL works, but maybe it uses the same approach as VSCode (which is different to how Google Colab loads the widget) and the same fix as described in the issue may work here too: Making sure to install the newest version of the widget (1.7.3). Please note that VSCode has some caching mechanism that made loading the newest version a bit tricky, so maybe this must be considered here as well.
DanPatterson
MVP Esteemed Contributor
both document links you provided give the answer.  Don't use *,egg files.  It is just a warning, so it should have installed.
You can install yFiles Graphs for Jupyter using pip. Run the following command in your Jupyter Notebook or command line:
and if that doesn't work, then see the alternates at
Installation - pip documentation v24.1.2 (pypa.io)
... sort of retired...
DISIG
Thank you for your answer Dan,
for me the code below works in google colab but it does not on agol.
w = GraphWidget()
w.nodes = [
{"id": 0, "properties": {"firstName": "Alpha", "label": "Person A"}},
{"id": "one", "properties": {"firstName": "Bravo", "label": "Person B"}},
{"id": 2.0, "properties": {"firstName": "Charlie", "label": "Person C", "has_hat": False}},
{"id": True, "properties": {"firstName": "Delta", "label": "Person D", "likes_pizza": True}}
w.edges = [
{"id": "zero", "start": 0, "end": "one", "properties": {"since": "1992", "label": "knows"}},
{"id": 1, "start": "one", "end": True, "properties": {"label": "knows", "since": "1992"}},
{"id": 2.0, "start": 2.0, "end": True, "properties": {"label": "knows", "since": "1992"}},
{"id": False, "start": 0, "end": 2.0, "properties": {"label": "knows", "since": 234}}
w.directed = True
display(w)
[Open Browser Console for more detailed log - Double click to close this message]
Failed to load model class 'GraphModel' from module 'yfiles-jupyter-graphs'
Error: Script error for "yfiles-jupyter-graphs"
http://requirejs.org/docs/errors.html#scripterror
    at makeError (https://notebooksservices1.arcgis.com/27be4f33be3945fc98c22c5ced05f817/static/components/requirejs/require.js?v=d37b48bb2137faa0ab98157e240c084dd5b1b5e74911723aa1d1f04c928c2a03dedf922d049e4815f7e5a369faa2e6b6a1000aae958b7953b5cc60411154f593:168:17)
    at HTMLScriptElement.onScriptError (https://notebooksservices1.arcgis.com/27be4f33be3945fc98c22c5ced05f817/static/components/requirejs/require.js?v=d37b48bb2137faa0ab98157e240c084dd5b1b5e74911723aa1d1f04c928c2a03dedf922d049e4815f7e5a369faa2e6b6a1000aae958b7953b5cc60411154f593:1735:36)
DanPatterson
are the packages the same in both environments?
fskpf
DISIG
No more error message. thank you.
DISIG
Hello every body,
!pip install yfiles-jupyter-graphs --upgrade
I will give some news when the graph functionnality will be integrated to my script that tracks items's relations inside an agol Site 🙂 .
fskpf
Nice to hear that it worked on your end as well!
I would love to see your integration. I've yet to see an integration in this field.
