Utility Network analyst - flow Direction
1575
01-10-2012 07:02 AM
SanjianMalapermal
Hi, I have created a Geometric network on one of our companies electrical networks and set the flow.  Is is possible to define the proximity of each of the flow arrows as it is currently too far apart.
Thank you
MalapeS
RobertBorchert
Honored Contributor
No you cannot.  The arrows are in the middle of the line and there is only one arrow per line segment.  If you wish more arrows you can manually split the line and it will place two arrows where there was one.
Thank you
MalapeS
